I pulled the codes from the ECU and it went (Flash..Flash 2.5 sec delay Flash..Flash) I am guessing that is code 22 from what I have read.
My problem is that after 5-6 min of driving my check engine light will come on and my truck will begin stalling, loosing power, and often dying at lights. Would a bad coolent sensor realated to code 22 cause the truck to die at lights? If not does anyone have ideas of what else it might be. Someone suggested it could be a bad oxygen sensor but I did not get a code 25 when I pulled the codes.
I did notice that I need a new radiator cap, the old one dried up and cracked. Since a small amount of fluid is leaking through the cap could this cause a faulty read from the sensor and trigger a code 22. If not, how difficult is it to change the coolant sensor and will most places (Auto Zone, Oriely, etc.) carry them is stock.
