1 - 8 of 8 Posts
Thug Engineering ST185's
READ the codes First!!!!!!
as above you would like to know WHY its on even if its a temp sensor failing
save you some money in long run !!!!
Thug!
i heard a way you can actually go into the diag and jump 2 terminals with a wire, and it will flash a certain sequence on the check engine light inside. and depending on how many times it flashes that determines what is wrong with it. honestly i dont know much about the method but it can be done.
1 - 8 of 8 Posts
