codes 43 and 21
632 Views 3 Replies 0 Participants Last post by  Ray O
G
These are the diagnostic codes I'm getting after my 92 4runner check
engine light started up last night. Are there really 2 unrelated
things that happened to go at precisely the same instant, or does this
indicate a third, bigger problem? The vehicle is running fine. I'm
worried that my ECU is causing all of this, and I'm not bright enough
to do electrical diagnoses
21=
OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER SIGNAL
OPEN OR SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR SIGNAL
43=
STARTER SIGNAL--NO "STA" SIGNAL TO ECU UNTIL ENGINE SPEED EXCEEDS
800RPM
--IGNITION SWITCH/CIRCUIT
--ECU
1 - 4 of 4 Posts
G
"Joe" <[email protected]> wrote in message
news:[email protected]
> 21=
> 43=
> 800RPM
> --ECU
I don't think the two codes are related unless someone or something has
disturbed a wiring harness between those components and the ECU. ECU
failures are very rare. Since you happen to have a short or open in 2
different components, I'd check the O2 sensor before replacing it.
Ray O
correct the return address punctuation to reply
G
well today sometime after doing the diagnostics the check engine light
went off. Maybe it was all a bad dream.
G
I believe both of those codes have a 2 trip detection logic. If you take 2
good trips without the ECU sensing the fault, it turns the check engine
light off.
Ray O
1 - 4 of 4 Posts
