Codes after belt change
622 Views 3 Replies 3 Participants Last post by  H2oRat
Thanks for the help folks pointing out I had the camshaft pulley on backward after a timing belt change. Next issue is I am throwing a fistful of codes. Engine runs great, drives good, middle temp range but code reader reads. P00016, p0018, po 325. I ran the engine until full warm up without the timing belt cover and all the timing belt Mark's were where they should be. My oil is stp 5w-30. Oil seems to be a common denominator for these codes but is 5w 30 the issue?
1 - 4 of 4 Posts
2 match up with the cam position sensor and the 3rd to the knock sensor. Doubt oil is the issue.
A point of commonality: The harnesses are on the transmission side of the engine. I would start by looking for damage to the harness shielding or grounds
Thank you I live in a salt air environment where 95 percent of the 12 volt issues are a bad ground. The timing Mark's being spot on and still throwing codes had me scratching my head.
1 - 4 of 4 Posts
