1 - 3 of 3 Posts
Hi Guys, I'm replacing my valve cover gaskets and the coil seals are stuck and I can't get them out. I lifted the 2 little metal lip that hold them in, but when I try to pry the seal up it's not moving. Any ideas you can share on how to remove them? is there a penetration spray I can use?
I just did mines. The inside ring usually breaks. I just use a pry tool. You can probably bend a flat head screw driver about 10-15 degrees.
Thank you for your reply. I put some force on it and managed to pry it out. 10-15 degree trick worked.
1 - 3 of 3 Posts
