finally got my coilovers in after like 3 months. right now i only have pictures of them uninstalled. i'll probably have some more pics in a couple days.
well i started off with tein s-tech on stock struts but after a while i found them unfullfilling. there was too much bouncing around. so i needed something more, but didnt wanna go with a strut/spring setup so i got coilovers. they are pretty pricey but for coilovers they're pretty affordable. let's just say the msrp for these are about 1200 but prices range as usual.
during the install, i ran into a few minor problems. for the rear, i adjusted the camber from the bottom a little too much negative and the wheels rubbed onto the spring. i loosened 2 bolts and pulled on the hub and tightened it back up. now it's got some decent camber without rub. on the front, i matched the total length of the stock strut to the coilovers and bolted it on. it was funny because it lifted up the car about 3.5 inches. i fixed that right up using the adjustment on the bottom of the coilover so it doesn't mess around with the spring's compression. now all 4 wheels are tucked about 1/4 inch into the fenders. imma need to lift it up a little so it doesnt rub on every corner i take.
handling-wise, it takes some time to get used to them. it went from bouncing everywhere, to taking hits everywhere. when i take right turns at like 20+mph, the rear right wheel lifts up. i can't really do this on left turns because they're not as tight as right turns. on sweepers, bodyroll is almost completely eliminated.
only things i can really think of that are weird are that i can't stick my small craftsman jack under the car anymore. i have to roll up on a 2x4 to get jacked up which kind of sucks. now i need to carry a 2x4 with me everywhere. also, unline tein dampers, the adjustments don't "click" on every adjustment made. d2 provides a simple marker that tells you where your adjustment is made. basicly, every full knob turn is equal to 6 points in adjustment.
i think i've said enough. maybe i'll put up some videos of the car's behavior when i have time.
