1 - 19 of 19 Posts
I have a 01 tacoma and have put a cold air intake on, and my check engine light keeps coming on. The reader said that the intake is the problem in that it is getting too much air. How do I make that stupid light go off? Is there a diffrent air/flow sencer that I can put in? What can I do? Any help would be great.
· 96 3MZ M/T
Camry
take it too autozone and find out why it is comming on and the code for the light. come back here do a little search for the code. or your o2 sensor could be bad
· nice guy
what is your problem jeremy...you just say "kool" to every post.....what are you retarded.:mad: :disappoin :hammer: :thumbdown
you said the a/f sensor is okay, but the check said something was wrong with it?
· Trailer Trash Engineer
Have you gone back and checked for any leaks in the new intake? Are all the hoses hooked back up to the right places?
Discussion Starter · #8 ·
Yes all the hoses and every thing is where it susposed to be. My mechanic said it is getting to much air for the sencer. I was just checking to see if anybody had any ideas or suggestions on what to do other than putting back the factory aircleaner.
I can't see it getting too much air. I have an aftermarket intake on a 97 4Runner V6 with headers and exhaust with no problem. That moves quite a bit more air than stock. My friend has one on a 2K Tacoma 4 cyl with no problem. There are tons of these kits out there. There must be something else going on. What code are you getting exactly? Give us the actual numbers.
Discussion Starter · #10 ·
The code is P1130 and the possible trouble ares could be; open or short in A/F sensor circuit, A/F sensor, Air induction system, fuel pressure, injector, or ECM. I just asssumed that with the new air cleaner and the majority of the problems on the list are air/flow related.
· Sleeping While Awake
u might need to take out the fuse for your ecu, leave it out for 15 minutes then put it back in
Yeah, clear the computer first, then see if the code come back. If it does, check resistance at the connection to the ecu as well as at the afm to make sure the wiring is ok. Check again for leaks in the system.
99 Taco
How long have you had it on the truck? I've heard where some vehicles take a little time to "get use to" all the extra air and after a few weeks they are fine. Allthough I have not heard of this with a toyota.
Thanks for posting the end result. Many times we never get to hear what the outcome was.
My understanding of OBDII which is most 1996 models and after, the only way to clear codes is with a reader. My manual confirms this. It will be interesting to see if pulling the fuse does anything. I haven't had any luck with that only using a reader to clear codes....
1 - 19 of 19 Posts
