Auto trans, A340E, v6 1997 T100
This problem started a while ago,
One month ago as I drive away from the house in the morning the trans acts strangely and won't shift up to 2nd gear, it catches my attention, then shifts smoothly from there on out. No problem shifting for the rest of the day. Several days pass, no difficulty with the 1-2 shift, then after sitting overnight, it won't shift 1-2 until it's warmed up. Now I just let it warm up, temp gauge up to midway, and she shifts like out of the show room.
I want the problem solved so I talk with my local mechanic he recommends taking it to the dealer; they're the experts and all. I follow the advice. After a day in the shop the service writer, calls.
"Mr. Wilson, you need to have the solenoids replace, valve body overhauled and it will cost you 1,300.00" I gasp, ask for time to think it over and hang up. I debate with my self and figure, go ahead and fix it, it's a good truck and a bad transmission can happen. So I call the dealership, negotiate the price down a bit; feeling smug I authorize the repair. Later buyer's remorse sets in but I rationalize," it's a good truck and you'll keep it a long time. They know what they're doing" and so on. I'm told it needed to stay until the end of the following day to complete the repair. Late the next day the service manager calls, "we can't find anything wrong, the solenoids work fine, and we don't want to go forward with this repair." Have you thought about swapping out the gear box? I'm shocked, what are they telling me? I change my mind, instruct them to stop work and put it back together. " We'll have to charge you 86.00 for the diagnostic work, I say. I don't like it but, put it back together and I'll pick it up."
Since then, at two independent shops, first shop's free diagnostics found; no computer codes and vehicle is safe to drive, they did not drop the pan. Second shop: kept the truck overnight, test drive in the morning showed the 1-2 shift delayed until engine reached operational temp, then no problems, codes or any thing wrong. Except they dropped the pan, now they say brass in the pan, or maybe it's babbit and the entire box should be rebuilt. I thank them for the observation and cautions that it will fail catastrophically and so on. I say, I'll take my chances and when or if it does fail I'll invest in it at that time. For now I'll let it warm up and drive it. No kidding after the initial shift it drives as if it came off the dealers lot, no slip, sounds, clunks, nothing, runs and shifts great.
Now I'm not too sure if you have an answer for all this but I'm really interested in finding out why it would behave the way it does and if there's an easy, or at least do-able fix for the problem.
I look forward to your comments and answers.
Al
Al
