1 - 20 of 20 Posts
I smell McNuggets
Ok so I'm having an issue where if I leave my car long enough so that the engine cools down, when i go to start it back up, it kicks in and turns over, but the idle and stuff doesn't stay high enough to keep the engine running so it stalls after like 1 second. I did a bit of searching and was thinking it might be the coolant temperature sensor, except that my temp guage on my dash is working fine. Another thought would be that it was the themostat. My dad says that we had this problem fixed a few years ago (I guess it's back again) and that they replaced the cold start injector, but after doing a bit of research i've learned that my I4 doesn't have one of those. So any idea what they might have replaced and how easy it would be to replace again?
Try cleaning the Idle Air Control valve.
To access it, remove the air intake hose from the throttle body , on the lower surface of the TB you will see a square opening, Spray an Oxygen sensor safe solvent into it, (you may have to do it a few times) hopfully it will disolve the crud that is in there, to permit the valve to move freely.
HTH
JerryR
I smell McNuggets
Discussion Starter · #3 ·
I don't think that's it. The car works fine when the engine is warm, and occasionaly (1/50 starts) the high idle will catch and keep the engine running. Otherwise i have to give it some gas to keep it running.
I smell McNuggets
Discussion Starter · #4 ·
Ok so i went down to the toyota dealership today and got the repair history for the car. Aparently, what was replaced last time was the Idle Air Control Valve because it was scored and was sticking. I guess this is haveing the same problem again. I'm going to try and take it out tonight and see if i can clean it or something. If not a new one of these is $250. Aparently it's not the temperature sensor because when those die, the check engine light comes on.
94 Cam LE I4: Many people have replaced the IAC only to have the problem reappear a year later. Most say clean it, I have also heard that some also lubricate it after cleaning. Seems that there is metal to metal contact in the valve that benefits from lubrication. Having the same problem myself. Have tested the valve many ways as per the factory repair manual and everything checks out ok. Only have this problem if the car is sitting for more than 10 hours, less than that it cold idles ok. Will have to try the lubrication of the valve, if only it wasn't so damn cold out.
I smell McNuggets
Discussion Starter · #8 ·
I plan on cleaning both the throttlebody and the ISC tomorrow. I'll let the car cool down all night then start on it in the morning. I picked up a new gasket from the dealership for a few bucks today and some STP throttlebody cleaner from autozone. I'll use a toothbrush or something to clean the whole thing and i feel pretty confident on taking it apart.
94 Camry LE I4: They used a lubricant used for motorcycle drive chains, forget the brand name. I'm going to try a little silicon spray and then cycle the valve open and close by pulling the plug and putting +12 volts to the center male terminal and then alternately ground the bottom(open) male contact and then ground the top(close) male contact. I have made wire leads that I can use that are insulated(used a butt connector flattened out a little for the female part of connection) at the contact points so I don't short out anything. I have cycled the valve before and it performs ok. I figure it has to be binding somehow when sitting for a long period of time. This valve is a real pain in the a** for a lot of people. If this fails to work, I might have to test the output from the ECU itself. This test is the only one the factory manual doesn't say to do. It says to test all the way to the ECU, but not the actual signal output from the ECU. It say if all tests are ok, replace the ECU. I think I'll test the output of the ECU first, thank you much. I noticed that the valve goes to mid position(800 rpm) when the plug is unpluged from the valve. I would have guessed that it would have stayed at its last position before being unplugged. I have also checked all the other sensors involved with the performance of the IAC, specifically ECT, IAT, etc. Except for the over 10 hour cold idle, it performs perfectly.
deviate from the absolute
92 toyota camry
Jeez SHawn, I'd hope you'd have a winter car by now......but the throttlebody is my guess man, see ya in the spring...hopefully
I smell McNuggets
Discussion Starter · #11 ·
Well i pulled it all apart right now. Not too muh gunk in there, but the deposites look like crudded oil. Probably not oil. So i used some cleaner and some pipe cleaners to try and clean everything out as best i can. The throttlebody is really nice and shiney on the inside now. But i feel like there wasn't enough crud in there to really be blocking it or making it stick. So i'll let it sit for a little bit and dry out, and i'll try making those test leads you made and see if i can't get it to turn properly and then put the whole thing back together and see if the car starts. I doutbt it's the ECU because if it was, the check engine light should be on.
I smell McNuggets
Discussion Starter · #13 ·
Nah the car starts but then instantly dies. I tested the solinoid for the ISC, it seems to be working ok, except that it doesn't FULLY fully close, there is like a sliver when i have it connected on way, a bit more when it's at rest, and it fully opens when i connect it the final way. So i'm going to package it all up and put it back together and make sure the hoses are on real tight anse see if it cold starts. Otherwise i might just have to drop it off at the dealership and see what happens.
I smell McNuggets
Discussion Starter · #14 ·
IT'S ALIVE!!!!!!!!!
Ok after putting it all back together, things must have worked cause the engine started 4 times in teh dead cold of this 17 degree freezing temp. The true test will be tomorrow morning, but i'm feeling optimistic. Thanks for the posts and to the outher countless threads that allowed me to peice together what was wrong.
[SMAN] said:
IT'S ALIVE!!!!!!!!!
Glad that your problem was solved. I just had the same problem on my 94 4 cylinder. Just yesterday I removed the snorkle to the throttle body and sprayed the square opening to the idle air control valve with throttle body cleaner. It was 18 degrees here this morning and the car started right up and held the idle at 1500 RPM. That little bit of oil you saw in there can get really thick and tacky as the temperature drops down causing the valve to stick. These deposits are actually a combination of oil and dirt. The EGR system recirculates the combustion gasses through the air intake plenum so that they can be reburned by the engine. This results in some oil and dirt being deposited into the plenum and the throttle body. That's why it's a good idea to clean the throttle body about once a year. I would like to caution the people who are spraying silicone into the idle air control valve that silicone can ruin the oxygen sensors. JerryR said it best; "Use an oxygen sensor safe solvent" only. You can use throttle body cleaner or carburator cleaner. They are designed to remove these types of deposits and are oxygen sensor safe. IMHO.
Mike
94 Camry I4: Cleaned my IAC many times with sensor safe cleaner with no help for my lack of cold idle. Used the silicon spray to lubricate the IAC valve. Cycled the IAC with engine off to work lubricant in. Gave it enough time so the carrier agent evaporated. The silicon clings to the the IAC very well so I feel it will not be carried into the intake/engine system. It solved my problem of no cold idle, cold idles at 1300 rpm now. No sign of oxygen sensor malfunction.
How do you cycle the IAC? Also, all I see is a little hole leading to the IAC, is that where you spray the lubricant? (I happen to have some extra motorcycle chain lube I got before realizing my '86 Honda Shadow is actually shaft driven, oops). Mine's a '99 Camry 4-cylinder. I tried cleaning the IAC and Throttle Body, but the problem, while better, is not solved. I get intermitent rough idle after starting up when warm or cold (only during startup, not when just coming to a stop like at a red light) and to keep it running I need to give it a little gas for about 15 seconds. Any advice is appreciated.
Thanks!
Thanks!
Yes, that hole leading to the IAC valve is where you spray, however, I would not spray motorcycle chain lubricant down there, or any other spray lubricant. Do not spray things in to your engine that will be burned inside the engine, that are not O2 sensor safe. I would spray a heavy dose of throttle body cleaner or O2 sensor safe carb cleaner down there and let it soak for 10 minutes. Then, reassemble everything and take the car for a 10 minute ride. IMHO.
Mike
NYR
I had a perfectly running camry and 2 weeks ago I decided to clean the throttlebody and ISC with carb cleaner and it fucked up my ISC causing my throttlebody not to close all the way on light throttle. The only way to get it to work is to goose the pedal to get the butterfly to close all of the way. When the car is NOT running, the throttlebody does not have this issue. My mechanic says I screwed up the ISC by spraying cleaner into it. My advice would be to be careful and remove the ISC before cleaning the throttlebody!!.....apparently the cleaner can do damage to the electrical components of the ISC.
I read a post in a thread about NOT to clean the ISC, and that it can damage it.....of course I read this after it was too late:sosad:
Took it to the mechanic, she replaced the IAC valve (which isn't as easy as you might hope, the gasket has to defy gravity for a moment and you need long arms with small hands that are double jointed ... or something) which is a $200 part. Have had 15 trouble free starts since then (two days ago), so I'm keeping my fingers crossed that this was the problem. She kept the old one for me to look at and it was not in "terrible shape" but I had just run a can of deep creep carb cleaner thru it and it still looked pretty beat up (from the inside).
Mechanic said these were a known problem and many were replaced under a "maintenance program" (a way of avoiding a recall we suppose). The replacement is certainly different looking and has a different part number though I confirmed with the dealer that it is the correct replacement (they didn't carry the old number part and the computer told them to use this one instead).
Happy with the solution so far, I'll report back if it turns out to only be a partial solution. Thanks for everyone's helpful comments!
1 - 20 of 20 Posts
