1 - 5 of 5 Posts
corolla 99
hi , my corolla have a cold start problem , I dont know why exactly, the engine want to die during the first minute of starting-driving only
when engine is hot , everything if fine and the engine idle well at 1k rpm
this is a video of me starting the car ... after a couple of try I choose to press the pedal a little .
Any idea
I would start by checking all the service items,like plugs,leads etc
If all that checks out it could be worth looking at coolant temp sensor,clean throttle and idle valve.When the fault occurs you'd need to check if there is a good spark and fuel pressure,this will help narrow it down.
2005 Corolla
x2 on cleaining the throttle body and idle air control valve.
corolla 99
the coolant temps sensor do a job at cold start ?
where it is located ?:eek:
corolla 99
can it be the IDLE CONTROL VALVE ???
1 - 5 of 5 Posts
