TOOLS:
Procedure:
1) unplug the MG/CL connector
2) connect the red wire to the car (-) battery, connect the black wire to (+) of car battery
by connecting to battery the MG/CL will be activated so ;
3) you can easily loosen the bolt
4) remove this and o-ring washer
5) remove the snap ring
6) remove the pully
7) remove the MG/CL snap ring
8) remove MG/CL
NOTE:
when you want to assmble the MG/CL be sure to put the MG/CL in correct place.
by using digital multimeter the resistance of MG/CL should be almost 4 OHM.
Procedure:
6) remove the pully
8) remove MG/CL
NOTE:
