1 - 3 of 3 Posts
On cold mornings in NH I get consensation on both the outside and inside of my windshield. I own a 2008 Tacoma access cab. Does anyone have a suggestion for the cure of the inside moisture?
My Other Truck
Welcome to TN from NorCal!
A very slight amount that dissipates quickly could be normal, just from moisture in the air. Any more than that may indicate damp carpets or upholstery, and you'll need to get them dried out. Your truck's A/C will remove moisture, so have the button pushed even if you're running the heater or defroster. I know, the compressor cycles on & off anyway -- but there's a chance it might engage more frequently if the button is pushed... I don't know.
Was a 05 Tacoma 4x4 DC LB
Check your inside condenser drain hose to make sure it isn't plugged. That might be leading to excess moisture in the cab.
Reactions: wjabarton
1 - 3 of 3 Posts
