1 - 3 of 3 Posts
hey i connected the df toy and before i put everything back i tested it out. i turn the car on and the radio doesn't work. i get power to everything else but the radio like the air bag light and clock work and the emergency lights but not the radio. i disconnected the dftoy to see if the radio will turn back on but it doesn't. dont know wut to do thanks.
Row Dialin'
Well it sounds like you didn't disconnect the battery. Did you check the fuses and see if you blew one. I don't know if the radio has it's own fuse but that's the first thing I would check out.
Also: You should really mount everything back into place before trying it out. You probably wouldn't have this problem if you did that. Sure it's a pain in the ass to take it back out but it saves yourself the hassle of replacing fuses.
Banned
I just went thru something similar...
There are 2 fuses in the fuse box under the hood marked "radio 1" and "radio 2".
There is a 7.5 amp fuse in the cab (under the dash/behind the change holder) that is marked "acc". This little guy killed my power, too.
1 - 3 of 3 Posts
