41 - 50 of 50 Posts
05 Tacoma 4x4 DC LB
Most Gen2 highlander owners are using the Zerex Asian (even mixing it when needed with OEM) without issues.
Not that it makes any difference to photobucket, but I cancelled my account with them. Ran into the same problem on some other forums. There are plenty of other photo hosting services out there besides photobucket.
Please name some names so that the rest of us can be brought up to speed.
Just in case someone needs the fender piece and clip ("button" as you called it):
Fender Apron Seal (Left, Right, Front, w/out KDSS): Toyota part #: 5388560030
Clip((5 for each) - for Front Fender Apron Seal, w/out KDSS): Toyota part #: 9046710186
I did drain and refill yesterday. i did not open block drains. I dont like to mess, because any reason its create a leak there, you will never find due to hot block.
as long as every 50K you drain and fill, you will be find.
only thing upset me was you cant take out overflow bottle out for cleaning.
must be glued.
41 - 50 of 50 Posts
