http://www.toyotanation.com/forum/1...olant-change-toyota-camry-2003-le-2az-fe.html
see this thread, esp the last 2 pages
the thread got closed
anyways, they suggested that I take my car to the dealer to get it checked out or to go to an "indy shop"
i went ton an "indy shop" and they used that prestone coolant tester (so no super expensive equipment/refractometer) and they said my coolant was "full strength" rated at -34, which means maybe I don't have issues and that my coolant is fine and that I flushed most of the water out.
I also scheduled a toyota dealership appointment on tuesday (in a few days) for them to check out my ratio and to maybe buy toyota red or have them top it off for me
but I'm thinking because the air bled out, the reservoir was pretty empty, so I added some pink (just a small amount) so the reservoir has coolant, but it's far from the "full mark" and I did this so I could leave some room for a top off with full strength coolant.
I saw Pentafrost A1 was 25 bucks just as toyota red is, but is the pentafrost the same as toyota red? I put zerex 50/50 after a water flush, and some ppl warned me of its dangers, but after going to the indy shop , they said my coolant was 50/50 and that I didn't have a low amount of coolant.
peak global is cheap as well. could i just skip going to the toyota dealer and add some peak global with the zerex pink I put in?
Also, it's only been a week since I did the flush and I noticed there were already black bits/pieces in my overfill reservoir. When I did the flush, I flushed out a LOT of black flakes you could see in the old coolant, but why are the flakes appearing again?
I used to have toyota red mixed with peak in my system before I did my flush last week, but 3 months or 4000 miles ago, prestone was added, and I heard that was bad for toyotas and that prestone is a disaster and leads to water pump failure
are the black flakes a bad sign?
and is peak global a good solution for a top off, or should I just top it off to "full" with my zerex asian vehicle coolant, or should I use Pentafrost A1 or Toyota red? Or is peak or zerex fine?
