1 - 15 of 15 Posts
i have a 2013 Camry XLE 4 cylinder. What is the OEM coolant for a flush and fill? The manual states “Super long life coolant”. Would that be red or pink and does it matter?
Thanks!
イリジウム
Aisin ACT002 "Pink" Super Long Life (SLL). $13.62 premixed gallon. Local parts store may have the Pentofrost A4. That will work too.
Yes, the same for your other 2008 Corolla.
And use the 5% off discount code if you buy from rockauto, scroll to the newest post:
This is my first car with the pink stuff and the 50/50 formula changes things. It's not really convenient to FLUSH with water the way we used to do. The reason being the new coolant is already reduced to 50/50 and if there's water in the system, short of getting ALL the water out, the refill will be less than 50% coolant. I think the dealer if necessary, will flush with coolant instead of water since they have the machine to do it.
I have a 2013 and I just drained and refilled the radiator and plan on doing that every couple of years to stay ahead of it.
Discussion Starter · #6 ·
I’ll do the same. Haven’t drained and refilled my 2013 yet. I’ve got about 50K on it.
J.O.A.T, Master of none
'14 Tacoma DC/LB
Toyota pink only IMO. I've had 7 Toyotas since 2006 and never once had a coolant issue, thermostat issue, heater core issue, or even a hose issue. I'm old school, I tried to replace the hoses in my 06 Tacoma and was told "no one changes hoses unless they get damaged in a collision".
Put Prestone or Dexcool in that thing and watch it rot out from the inside like all of my vehicles did when I was growing up!
Discussion Starter · #10 ·
Replaced both my 2008 Corolla and 2013 Camry with Toyota pink. Now, I'm trying to figure out the best way to replace the transmission fluid in the 2013 Camry 4 cylinder. The Corolla was a breeze.
2012 Camry SE
I recommend you have it done at your local Toyota dealer for piece of mind. That’s where I had mine done.
Discussion Starter · #12 ·
Will do! I'll check in it. I've got about 50K on my Camry. Wasn't sure when the transmission fluid change should be done since I plan on driving it a long time.
Coolant is rated for 5 years as per Toyota owner's manual. That is for the Pink Super Long Life Coolant as per the owner's manual for my 2016 Camry.
I had it done at a Toyota dealership using their machine for this.
My owner's manual does not list changing the transmission fluid, just checking it at 100K miles.
My own system is that I had it changed at 60K miles and may do it every 30K miles thereafter.
For transmission change, I had full exchange of the fluid done at a Toyota dealership.
Other vehicles, I did these things myself.
For the coolant, I was just lazy and if I still have the vehicle in 5 years, I will be lazy about that again.
For the transmission, this vehicle is super sensitive on fluid level, super small margin for error, so I left it to the dealership to do for $200.
Discussion Starter · #14 ·
1 - 15 of 15 Posts
