1 - 12 of 12 Posts
· Supafly
1991 toyota pickup
Did you seal up the hole that you drilled to fit the other bulb in?
Thats exactly what I was going to do, drill a hole and install the turn signal bulb into the marker so it does both. Mark the ends and turn signals, just like you did.
Would want to seal it with RTV or something to prevent that condensation..
Just gotta think of a way to make the bulb/socket removable for when the bulb burns out.
'06 Seinna XLE AWD, '04 Highlander V6 4WD
Socket
Mybe just epoyey a old twist look from a old corner light assembly in so you can just twist and install/remove?
HiluxSupraISF
Discussion Starter · #11 ·
I used black RTV. enough to seal the thing, enough to hold it on, and easy to remove and clean off when you need to change a bulb, just RTV again.
and if you're in a bad situation... duck tape? lol
1 - 12 of 12 Posts
