G
Guest
·"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
[email protected]
> "Ghislain" <[email protected]> wrote in message
> news:[email protected]
>> My daughter's '97 Corolla power steering is rather stiff when it's cold,
>> e.g., 15°F or lower. It's fine after driving the car for 15-20 minutes.
>> Would replacing the power steering oil make a difference or is the
>> stiffness caused by the rack and pinion?
>> Thanks.
> There are a couple of possible causes for high steering effort. Replacing
> the power steering fluid may make a difference. Also check the condition
> of the universal joint on the steering column.
> Ray O
> (correct punctuation to reply)
If I ask the dealer to check that universal joint, they should know what you
meant? Is it inside or outside the car? I would assume that it's outside
since the inside gets warm within 5 minutes while the steering is stiff for
a lot longer (it slowly gets normal). Can it be lubricated?
[email protected]
>> Thanks.
> Ray O
