1 - 3 of 3 Posts
S
Guest
Can someone explain how to remove the front right corner light on a
Toyota Corolla sedan, 1994? The light is next to the headlight. I tried
looking for screws but couldn't find them. I tried removing the
headlight first, but I see only one screw on the top - removing the
screw (and the radiator grill) did not help.
Nver thought changing a light bulb would be so tricky. Any insight or
suggestions would be appreciated.
R
Guest
Discussion Starter #2
"stilllearning" <[email protected]> wrote in message
news:[email protected]
The owner's manual usually has a section on cfhanging light bulbs. Is the
info you see in there?
Ray O
R
Guest
Jack mutters:
To change the front corner marker, remove the retaining screw. This screw
is located on the flat surface above the headlight, just behind the
headlight vertical aiming screw. It is nearest to the hood bump-stop rubber.
With the screw removed, slide the so-called 'lens housing' forward and it
will come loose. Rotate the bulb holder to remove it from the housing.
Good luck to you out in cyberspace.
1 - 3 of 3 Posts
