1 - 3 of 3 Posts
Hello guys,
I'm new to this forum. I actually have a question that may or may not have already been answered but will Corolla lowering springs fit an iM. I know the factory part numbers are different, but will everything still function as it should?
Thank you in advance.
· 10th Gen Addict
2011 Toyota Corolla
The Corolla iM (It's new name if you didn't know) has an independent rear suspension while the Corolla sedan has a solid axle rear suspension so the rear springs most likely won't fit. The front appear to be the same suspension between the two so only the front lowering springs would fit but at this point, you might as well get a Corolla iM specific lowering spring set.
1 - 3 of 3 Posts
