Hi all,
Father-in-law's 98 Camry, 2.2L/auto with 148k miles. Car was burning oil so I brought it to my house to change out valve stem seals, gaskets, etc. Before this it started flawlessly. Now after getting it all back together, it started up for maybe a second or two and then died and now won't restart just cranks.
During the work the timing belt was removed, along with camshafts and the rest of the valve train while I changed the seals. Everything was kept in order, one valve at a time. Yes the engine was at TDC before any removal and yes I put a 10mm bolt in the exhaust cam before removal. I just took the valve cover and timing covers off to verify timing is correct, and it is. Crank pulley at 0, cam sprocket aligned with "V" mark in the cam cap, dots on the intake/exhaust cams point directly at each other.
I checked and made sure I hadn't left the cam and crank position sensors unplugged but they're fine. I believe I'm getting fuel, I can smell it in the cylinders when I crank. I suppose I should check for spark directly. Battery is at 12.5V and I have it on a charger while I'm trying to crank.
Anything obvious I'm missing?
