On my 2001 Avalon I am doing a plug/timing belt change and adjusting the valves. Everything is out of the way and the valve covers are ready to come off. I broke the crank bolt loose, no problem. No problems so far, just a pain in the butt.
The problem is with the crank pulley, which is "supposed" to come off with "hand pressure". No way. I also tried carefully prying from behind. No way.
I DONT want to use a jaw-puller, too many posts about breaking/bending the pulley $$$$, warnings in the manual also.
Is there another type puller? Any suggestions to get this bit** off? Very little room behind the pullet to work with-. THANKS Wrenchy
