1 - 19 of 19 Posts
· Terrible mechanic
1987 camry wagon
Is there a trick to getting the crankshaft gear off? I cant get it to budge. Got my new oil pump ready and everything.
To remove the crank timing gear try the following:
Inject the WD40 into the keyway;
insert the flat screwdriver 3/8 inches wide blade between the gear and the oil pump casting.
slowly ROTATE (twist), not PRY the screwdriver the small amount; do the same about 180 degrees from the first place
· Terrible mechanic
1987 camry wagon
Discussion Starter · #3 ·
I have sprayed lubricating oil into the keyway I will try the rotate thing soon.
· JUST RE ENGINEER IT
98 Prizum
if hes getting the pump swapped hes already got the pan off, get underneath and get 2 screwdrivers on opposite sides and pry it off, if ya break the pump your putting a new one on it anyways
· Terrible mechanic
1987 camry wagon
Discussion Starter · #6 ·
I tried and tried. penitrating oil, big screwdrivers rubber mallets, nothing. Not a mm. in fact its capable of bending my big screwdriver (the 3/8" flathead) Im at a loss here.
· Terrible mechanic
1987 camry wagon
Discussion Starter · #8 · (Edited)
Yes I am speaking of the crankshaft gear in the lower right part of the pic. not the oil pump gear.
· Terrible mechanic
1987 camry wagon
Discussion Starter · #10 ·
I can understand what you mean. I am not sure its on strait but I dont see any inconsistancies on the area between the gear and the shaft. (meaning the wider area would show the other side of the gear is to close to the shaft) Ive pulled 1 other gear, but Ive pulled it off many times. first time was a real pain the in arse. after that it wasnt that hard. maybe its just been 60k+ miles since It was last off.
· Terrible mechanic
1987 camry wagon
Discussion Starter · #11 · (Edited)
Im getting real tired. I managed to damage the gear. not bad. but I did score it. (not on the teeth so I should be able to mend it) but still no movment (I can see) I dont know what do to. gear puller aye. Forgot
98 Prizum
if nothing else works, get all the bolts out of the pump and bust it from underneath where the oil pan was and after you get it all broken away get a bar behind it from underneath and drive it off
· Terrible mechanic
1987 camry wagon
Discussion Starter · #14 ·
cut up my old pump to get room to pry it off? Im hoping the gear puller will fit on it.
2002 Camry
Try heating it with a propane torch?
Also I see holes in the end of that gear, if they are tapped either use a puller or if you cant get one right now, just find two bolts that fit and drill a piece of steel to make your own puller.
· Terrible mechanic
1987 camry wagon
Discussion Starter · #16 ·
I needed to update this sorry. Yesterday I managed to get the gear off with the puller. it only took me chipping the old oil pump in a few places and then useing prybar to bend it to get the puller on. once it was on it came off smoothly. thank you for all your advice. As for the rebuild I put on new pump ( and snaped a bolt while installing it) installed the headbolts, torqued then, inspected and installed the camshafts. and the distributor. I need to get out there and install the strainer and that plate in the pan. maybe the pan but I need to locate the bolts for the pan.
Use Toyota seal packing (aka gasket maker), the black slow setting RTV, available from Toyota or Internet.I bought my for $15. Superior oil resistance and versatility.
Sealed the semicircular rubber plug to valve cover gasket on my supra , while was applied directly to wiped surfaces.(no other sealants were able to do that.
Use long M6 screw with cut head as a guide/locating pin for the pan, then install the rest of the bolts.
· Terrible mechanic
1987 camry wagon
Discussion Starter · #18 ·
I know of the black rtv gasket maker but Was wondering offhand of its virtures vs my normal grey rtv gasket maker. gray isnt like a 5 minute one or anything but it seems to work rather well.
1 - 19 of 19 Posts
