Can't remove my crankshaft pulley on my '97 camry 4 cyl. Anybody have any hints? Is it reverse threaded? What's the best way to hold my flywheel?
i've tried a chain wrench, and it works good at home, just wrap around the crankshaft pulley with the chain wrench to hold it still, and use the rachet socket wrench to loose the crankshaft bolt. i also use water pipe to extend the wrench arm longer.StusToyota said:Not where the starter goes, but from directly under the flywheel. Just pry over the flywheel cover and there you go. I've also heard of a guy using a strap wrench on the pulley, but I'm not sure about that one.
