1 - 20 of 20 Posts
I have a 2016 Corolla. I needed to jumpstart it and stupidly crossed the cables. When I went to get in the car as soon as I open the door the horn went off, that is when I disconnected the cables, hooked them up properly but when I went to try start it there was nothing at all. I changed the 120 amp alt fuse and checked all fuses under the hood and inside and change 4 under the hood and installed a new battery. So now what works is, I have radio, lights, door locks and trunk opens. What doesn’t work, I have no dash activity at all, as far anything in the speedometer area and car just turns over.
Any help would be muchly appreciated.
Thanks
· Long-haired Southern-Squidbillie
2004 Camry 2AZ engine; 2018 Camry LE
Was the key in the ON position when you connected the jumper cables?
If not, did you turn the key to ON with them connected?
If not then you might be able to salvage it, but if so then there are likely ECU(s) damaged from reversed polarity.
Discussion Starter · #3 ·
No the key was not on. I had the key in my hand. When I reconnected them the right way I turned the key on but when I didn’t see any dash lights i stopped. I did not try to start it.
· Super Moderator
you can also pay $20 for a one month sub to Alldata DIY and it will have complete factory wiring diagrams for your car
have you tried the NEW version of AlldataDIY? I have a 3 year sub till October for 1 year price to the old site and it sucks.
Check your local library. Since paper OEM manuals for Toyota have gone away they usually have subscriptions to AllData. You may have to go to the library to get the information and drawings of the electrical system you need.
All of my toyotas have had three fuse blocks. One in the engine compartment and the other two under the dash on the drivers side and one near the passenger kick panel.
Find them and check for other burned up fuses.
While critical circuits are likely to be reverse polarity protected, cross connecting also probably generated considerable sparking and rapid current surges that can generate high voltage spikes that might overwhelm over-voltage protections built into semiconductor containing circuits, causing either immediate failure or latent damage leading to failure down the road. Even with the ignition off, some circuits like alarms and those that operate door lights always are "hot" and some others are "on" for the purpose of detecting various activities, and they could be affected.
But first, keep looking for additional fuses and links, and even blown wires and PC board traces.
'09 Venza V6 AWD - '86.5 Supra 2JZ-GE
Fusible link is usually in the junction box under the hood. Hard to say on that year/model, but they typically look like a very large (thumb-size, approx.) plug-in fuse. Sometimes they are screwed in to the junction block with two, usually, 8 mm head bolts. The underside of the junction box cover should have a diagram with the labels of all the fuses/fusible links on it. That 's where I'd look first.
Pulled the same move on a '80s Toyota years ago, the fusible link in the underhood junction box melted. Fortunately no other damage.
· Administrator
マズダスピード3
Fuse is doing its job. Prevented electrical mayhem. Good job.
1 - 20 of 20 Posts
