As some of you may know, I'm working on that 7AGE build over in the Corolla forums. Reason I'm posting here is because I have a line on a CT-26 turbo from a neighbor's Gen 2 MR-2, in GREAT condition. For $100, it's hard to pass up. However, it IS a twin-entry turbo. I've seen custom equal-length single-entry turbo manifolds for the 7AGTE project built from a B16/B18 manifold and a 4AGE turbo flange, however given that the CT26 runs (apparently) 9 PSI stock and the engine's only been given a "that should hold up for 6-7 PSI" approval by the builder and also that it's twin-entry, is this something that I'm going to be able to bodge into place relatively easily? A couple questions:
1) Any way to decrease the boost?
2) I've heard that it 'runs out of boost' at around 5,500 RPMs...on a 2.0L engine. Will running it on a 1.8L engine let it pull up to around 7,200?
3) Twin-entry-- better to try and fabricate a twin-entry to single-entry adapter, then go with a B16/B18 manifold? Or would it be feasible to put a 4AGE flange on a 3SGTE downpipe?
4) Is there enough room in the engine compartment? =)
5) Generally, is this a good idea to try and shoehorn in or would I be better off looking for another turbo to begin with?
Thanks for your time.
