1 - 15 of 15 Posts
hi guys, would like to take this opportunity to introduce myself here. We do import a lot of JDM performance parts direct from Japan, involved in the supplying of turbos (used/refurbished/new) & we also do special requests to assist in your quest if you are looking for rare JDM parts.
Here we have a fully refurbished CT9 turbo for the 4E-FTE engine. Very common in the Starlet, Tercel & Paseo. Well, apart from being a refurbished unit, this turbo can be condired as good as new. New bearings, shaft and oil seals. Bead blasted, anti-rust coated & balanced.
Wondering if anyone would be interested in this unit.
We have an array of Toyota parts as well and will post very soon.
If you have parts in mind that you need, please do feel free to contact us.
Thanks
kind regards,
-C-
[email protected]
Discussion Starter · #7 ·
Hello Todem 76,
Yes we do turbo refurbishment & upgrading services.
Shipping cost would be $120. The cost for turbo repair will depend on the condition of the turbo, ranging from $100~$300.
We would highly recomend the complete refurbishment of your turbo which consists of new replacements of all oil seals, bearings, compressor wheel, exhaust wheel, shaft, rebuild rotor balancing, bead blasted & anti rust coated.
This would be as good as a brand new turbo upon completion.
kind regards,
-C-
[email protected]
Thanks.
Are there any upgrades such as porting out the wastegate and installing a larger flap for increased efficiency?
What kind of lead time are we looking at if it's coming from the U.S.? Or do you have a Core type system?
Discussion Starter · #9 ·
The lead time for repair or upgrading will be one week upon the receiving of your turbo. Yes, we can port the wastegate & install a larger flap if you are experiencing boost spike on your current set up. We can also cater to special requests for compressor wheel upgrading for greater efficiency.
kind regards,
-C-
[email protected]
1 - 15 of 15 Posts
