1 - 3 of 3 Posts
2013 Toyota Highlander Limited
I was asked about a grille I have on my Highlander. I made it out of two aftermarket ones. This is not my original idea I saw somebody has already done this and I really liked the looks. I used Polyvance FiberFlex to weld the pieces that I cut out from the donor grille and used ABS shavings mixed in acetone to fill in small cracks and teardrop notches. Also installed reinforcement mesh in the back. I had it professionally painted. Here are some pics from the process.
One of the two aftermarket grilles
342809
Started by cutting out the bottom piece of the logo
342810
Used aluminum tape to hold the pieces together while welding the back
342811
Top was the most difficult to weld as the plastic is much thinner there compared to other places and I cut a little bit too wide so it took longer since I needed to really reinforce the back of the top rail
342812
All welded in the back!
342813
342814
Trying out the fitting of the reinforcement mesh
342815
Filled those teardrop notches with ABS shavings mixed in acetone
342816
Finished product
342817
Finished product on the Highlander
342818
Super Moderator
1995 T100 2WD & 1993 MR2
So very cool. Nice job!
Never even heard of that product for welding that material together.
Awesome. :cool:
1 - 3 of 3 Posts
