Howdy everyone,
Hoping you can shed some light on an issue I'm having with my Toyota Chaser X81. I'm replacing the fuel pump, and ran into a significant problem after dropping the tank. It seems that the hard line running to the pump, attached with a flare fitting, is completely seized and will not come off, at least not with the leverage and tools that I have while laying on my back underneath the car. However, there seems to be a section of soft line in between the two flare fittings. My question is: what would be the safest way to cut and splice this line so that I can get the fuel pump out, given that the flare fittings won't come off? I've attached a picture of the section in question.
