1 - 20 of 20 Posts
I have been thinking that maybe my best way to achive the small lowering im looking for around 3/4"- 1" would be to cut some OEM springs to achive this im not talking alot here i would think 1/2 a coil would be plenty to do this?
-whats it do to the ride hows it effect the spring rates?
Opinions and comments......... just say it i really don't care i just want some other points of view to help me make a decision...
G
not a good idea at all. if you really want to do this (which I dont suggest at all) you should use a hacksaw to cut the spring (because if you use flame it will mess with the spring rate). then, I would get some aftermarket shocks that support the drop your proposing (that way the shocks dont blow out which i guarantee they will - just will take some time and bumpy roads)
Resident asshole
Corolla
Theres nothing wrong in cutting springs. we've used angle grinders. Only problem is that a stock corolla spring isnt exactly a good candidate, theres too little coils. Plus you cutting ½ coil off will result in the spring being in an awkward orientation.
yeah, you need to cut 1 full coil in order for it to sit properly..... i've done it in an mr2 and i have a friend with cut springs in his mr2 (and his handles quite well)
corolla xrs
the eibach lowering spring will bring you about an inch lower and they are a really good quality
I would not cut the spring if I were you and if you really want to cut them I would get it done by somebody who know what he is doing
Discussion Starter · #8 ·
i have the eibach prokit, and there the problem, i should be able to cut only 1/2 or 3/4 because the tops front and back are closed and ground (sit flat)
actually it's a common problem with aftermarket spring companies for ae102's and ae92's.... they tend to not take into account that the rear fenderwell is lower on the body than the front.... and the car seems to have a rear rake...
and eibach's do have that problem...... as do suspension techniques..... hell, the eibachs on my mr2 make it look stock height......
in any case.... an old member on other forums had this problem with his ae102 (racer25).... he cut just the front coils.... didn't sacrifice performance and the car looked great.....
The TN Member
ae101 levin&trueno
Yea cutting springs is OK, not good, but better than commpressed springs. (anyone who's driven a car with compressed springs will agree with me).
Just make sure they are captive and still seat properly.
And it's probably not legal, its not over here.
For All The Pimps
Why not just add 300 lbs. to the vehicle weight? The car would drop about an inch. You could also get smaller wheels. I used to own a 94 Escort that was lowered. The struts were worn and caused all four coil springs to eventually break. One of the strut mounts was also partially broke. The ride was a little scary at the end, especially during high speed cornering manuevers. It went to the junk yard.
Seriously, cutting the springs is a very good way to destroy your car. Even if you can get a lowering kit, I would not recommend it. If your going to spend money on the car, why not upgrade its performance or reliability instead of the "pimp factor".
i've seen cars with cut springs outperform cars w/o cut springs...... it's very do-able, it's very safe... if you do it correctly....
READ ABOVE
4AFESPEED
93 Geo Prizm
There used to be some coil pinchers, snaps on like small spring compressors, tighten them down and you can lower it 1/2 - 1inch, look em up.
cutting factory springs would give you a weird bouncy ride. Done it before on my AE92 which I later replaced with Apex springs.
I cut my Tein S techs few months ago on my 06 Corolla. Drives fine and actually feels better than before cutting it.
G
why would you cut teins?:disappoin
1988 Corolla SR-5
I have cut stock springs on a few cars and have not been disappointed with the results.
I have been advised by people who had more experience doing this to:
(1)Never cut with a torch so as not to heat up the metal to the point of changing its temper (springyness)
(2)Cut only 1 - 1.5 coil off a stock spring. Usually 1 on the front and 1.5 on the back to get the car level. (This depends on the number of coils on the spring)
(3) Make sure the spring will still be captive. Measure it against the strut fully assembled without the spring. The spring should still be taller than the space it fits in with the strut fully extended, or at least not be able to fall out.
You are correct. Those guidelines are right.
1 - 20 of 20 Posts
