1 - 7 of 7 Posts
f$cking A!
I accidentally cut the wiring harness...close to the distributor. Does anyone have any idea how to fix this? should i just buy a new harness or what? how much would this cost if i brought it into a Toyota dealership to fix. ARRGGGGHHHHHH!!!!
God damn engine bay is pissing me off.....can't do sh*t in it!
Discussion Starter · #3 ·
i just soldered the lil connector pieces back to the wires....hopefully rosin core will hold up.
will this damage anything?....change in resistance...
do the wires get HOT? will this melt the rosin core?
any knowledgable response will greatly be appreciated. :)
1990 Celica GTS
You'll need high temp solder. 70C solder will melt. put a cramp connector on it if you can. A lose connection might kill you engine with spark fire at wrong time or not firing sometime. No need to worry about resistance.
Discussion Starter · #7 ·
i just used some wires and soldered the connector wires back to the harness wid some Rosin Core. it started up and ran just fine. i'm still kinda iffy about the quality though....i mean if the soldering will hold up. i'll just drive it until get some problems.
1 - 7 of 7 Posts
