Please help. I have a 88 yota 4x4.
My CV joint is bad an im half way through getting the thing out and now im stuck. I have already taken care of the hubs and disengaged the joint from the axle but now i cant pull it the whole way out. It is hitting lower suspension arm and it wont pass by it. Is there some trick to this or am i going to have to pull the suspension arms off. Any help would be greatly appreciated.
If you unbolt the sway bar link from the lower suspension arm, Then jack up the suspension arm until it is nearly level it will leave enough room for the axle to pass by the arm.:thumbup:
