21 - 24 of 24 Posts
check the #1 plug. New does not always mean good. Swap it with #2 and see if miss moves with plug.-never mind.
OK so, glad you got it fixed.
Wait- you were told the "fuel injection system" needs to be replaced because of "bad gas"? The system consists of many components. Pump, filter, lines, injectors and so on. Just what was in the bad gas? Usually it is water and draining the tank and adding good fuel and maybe an additive to absorb moisture and clean deposits is all that is needed. Do you have any more info on this??
but since gasoline is the lubricant for the system, all I can assume is that it's possible that water may have damaged a fuel injector?
21 - 24 of 24 Posts
