1 - 4 of 4 Posts
06 Taco 4x4 TRD
Guys,
I searched but didn't find the answer. Anyone know which color wires on the DAC connector are what?
jscheu
Green, pin 1: +12V from tail light relay (power when lights are on)
Green/White, pin 2: ILL- from dashboard dimmer rheostat (eventual path to ground)
Pink/Black, pin 3: Pin 44 of Skid Control ECU (on master cylinder)
White/Black, pin 4: Ground
Pins 1 and 2 power the little light in the switch.
Pins 3 and 4 tell the skid control ecu if the switch is pressed.
Why do you ask?
· Procurer of forks
'08 Tacoma
Discussion Starter · #4 ·
I found a thread with a good diagram doing just what I had in mind. I'd link it but I have enough trouble replying to the thread....
But thank you again guys! You guy are always good at helping with ??
1 - 4 of 4 Posts
