I'm presuming this is a 4WD based on the grab handles in the cab? Are you looking to restore it to running condition or fer parts?
Just a quick look...
Left fender seems to be a different color.
Left hub assembly is on the ground. Where is the brake caliper and hose?
Right frame extension is beat up. Won't happen unless it struck something.
Left frame extension looks bent down.
Left upper and lower ball joints missing.
CV axle is on the ground.
Obviously the fender, air dam, left parking light, and both turn signals are missing.
Why would the grill be all cracked up?
Antenna is missing.
A few bolts and hub grease cap are on the ground. What other critical bolts are missing?
Pliers on the dash?
Right side rear slider is not the same tint.
Left tie down hook is missing.
