1 - 11 of 11 Posts
Camry 2002 V6
He people I drove about 15 miles on a semi flat tire, at least I think! (It was the rear left side) I couldn't tell it was flat until I went around a sharp turn and the back kind of gave out, so i stopped to check out what was going on. Like I said I had a flat! So I drove the last 1.5 mile home! Like I said I couldn't tell it was flat unless I went around a turn! Do yall think I did any damage to the tire? I'm gettting it patched tomorrow I'm sure they will tell me what is up, just wanted to check with TN before I to the tire shop
THanks
98 Camry XLE V6
Wheen you get it patched ask the repair man if its bad or not. Depending on how u drove and a few other conditions your tire should be okay. Some damage has been done though. I wouldnt stress, especially if its a newer tire. If its worn out already, why not just get a new set?
TN Pussy Man
Camry
well, if it didn't roll of hte rim or break the bead, then at least it wasn't totally deflated
and as touringcamry said, make sure they dismount the tire to take a look- that's what you're paying them for- the other way, you can go to our local auto store and buy a patch it kit yourself
and the only thing you will have to look for is if there is any crazy sidewall wear, in case the tire was really underinflated
TN Pussy Man
Camry
you're lucky that you don't have low-pro tires, which means that you won't even feel a difference when you turn.....I didn't a while back, and look what happened to my tire after running on it for ...well.,....a while....and it involved highway I think
Midship Captain
1991 MR2 Turbo
I get a nail/screw/bolt in my tires at least once a month.....i know it sounds rediculous but its true.
So i carry around a Tire repair kit with rubber fill, you can rip out the nail and then Reem it out, and use a special tool to Insert the rubber filler.
Then after that i whip out my Slyme Portable Air compressor and pump the tire up and go :)
Cost me $20 for the compressor, and $3 for the Kit....havent spent a dime on a tire shop scince ;)
TN Pussy Man
Camry
^ really?
i'm surprised that you even realized that they tire was flat when taking a turn, espcially when it's in the rear
that tire that I showed was only on a 17" rim too, and was also in the back, and I had no idea until I had gotten to my ex's place and dropped her off
if it happened to my 18s now, I really doubt that I'd notice either...:ugh3:
1 - 11 of 11 Posts
