1 - 4 of 4 Posts
06 camry se
i have an 06 camry that came with the factory non-JBL system and has 2 dash tweeters, 2 6X9 in the front doors, 2 6X9 in the rear shelf
i am not getting any sound out of the front tweeters; i tried fading the sound to the front and disconnecting the door speakers but still no sound
as far as modification ive replaced the headunit, f&r speakers, and added a sub
the dealer said theyre around $100 a piece which is rediculous so im thinking of getting cheap aftermarket ones
for the dash tweeters should i take out the old ones and use the stock wires or should i run new wiring? im not sure if theyre just blown out or the wiring is shot
Cruisin' along
2019 Camry LE
the wiring unless subjected to rubbing against something, should be fine, just re-use it. the tweeters were probably cheap ones from the factory anyways.
06 camry se
i took the tweeters out and theyre trashed..... theyre covered in a white powder lookin stuf and the cones fell apart
only problem is the crossover for the door speakers is thru the tweeters so i need factory ones
anyone know where i can get them for cheap?
Cruisin' along
2019 Camry LE
go to the local bone yard for a recent totaled out car. should be good prices there.
1 - 4 of 4 Posts
