1 - 8 of 8 Posts
Hey guys I have a problem...I had my aftermarket foglights installed last week. At night I noticed when my headlights and foglights are turned on my dashboard light is dim. I also noticed my left headlight is alil dim as well. Have anyone had/have this problem? Could it not be wired properly? I believe it was wired through my left headlight and to the battery. I went to a place named Complete Automotive. I just wanted to get some input before I take it back to the shop.
2011 Camry XLE
Disconnect the fog relay, if the problem clears, something wired wrong.:)
· Here and there...
Camry 07
What kind of H11 bulbs are you using? Just make sure it stay within the OEM recommendation. I believe it should use 55w. If it's more you are at risk of buring your wiring harness.
Discussion Starter · #8 ·
Im using the ones that came with the OEM like foglights. I assume they should be the right amount of watts. Im taking it back to the shop today. If they cant get it right then I want them to uninstall it. This is so frustrating.
1 - 8 of 8 Posts
