Hey good one! I'll tell you how to do it.
Can you take some pictures when you do and make a DiY so I can add it to the sticky?
First you need a hair dryer. Heat up the badges that you would like to remove this allows the adhesive to soften. It make it easier to remove them.
Now using a piece of fishing line. (I like spiderWire) slip it between the badge and the panel to separate it from the panel.
After you have removed the badge use a small amount of Goo-B-Gone and remove any adhesive left behind.
Once the area is clean and free of residue. Apply a coat of polish/wax and you are done!
Good Luck!
I look forward to seeing your write up!:thumbup::thumbup::naughty:
Good Luck!
