1 - 11 of 11 Posts
Camryologist
1998 Toyota Camry
Sup guys...
I'm planning to buy Denso Iridium Spark Plugs for my 1998 V6 Camry and I think I'll keep the stock wires...
I checked in their website and the spark plugs for my car are the IK-20..
I started reading some more and found out that the higher the number (for example, IK-22, IK-24, etc...) the colder is the spark plug...
So, as far as I know, the colder the better ????? :dunno:
Would any colder spark plugs fit my Camry ?? If not, I'll just go with IK-20's...
Thanks...
Moving Forward
jsut stick with what the factory recommends.
unless you start doing modifications there really isnt much reason to change the heat range of the plugs.
The 6"4 Viking
Toyota Hilux 3.0D4D
Cold plugs is something you use in a high prefomance
engine with turbo or otherwise, this is to keep the plug
from overheating and to prevent predetonition witch
could destroy your engine, but as long as it has no major
mods on it then the standard heat range is the what you
should stick by.
.::{ XwORLD }::.
1999 CAMRY
hey i am about to change mine too (Gen4 V6)
i looked at my plugs on the car they are Denso Multi-ground plugs (PK20TR11)
so i belive they are factory replacments...
i dont know if to stick with them or to switch to iridiums ????
Stick with tthe 20's. PK (platinum)or IK (iridium)
IK22's are usually swapped in once you get the s/c.
TN's ExercisePhysiologist
96 S/CToyotaAvalonXL
^ i'm the above example. I use the IK22 for my s/c.
Lost to follow up!
96 Camry Coupes
Recently had the valve cover gaskets replaced on my 1mz, and the plugs were checked then, and they were same as the above!!........Runs great, no need to change IMO!
Camryologist
1998 Toyota Camry
Discussion Starter #9
So what if I'm planning to get Nitrous Oxide in the future..?? Would I have to change the plugs for that..??
And, what if I decided to put the IK-22's in without any major engine mods..?? Would that hurt..?? No difference..?? It would run the same as the IK-20's..??
Turbo S2000 FTMFW
2005 Honda S2000
i wouldn't think it would run any different, but i don't know.
As far as nitrous changing it...prolly not, nitrous isn't really something you run for extended periods, but let someone with more knowledge of nitrous verify that.
1 - 11 of 11 Posts
