21 - 40 of 63 Posts
'21 Corolla LE - Celestite (1K3) / Black (FB20)
So I went to my local AAP store and bought Silglyde, boots, bushings, and caliper pins. Just ran out of time today so I couldn’t install anything. May not be able to get to it for a week. I should be ok until then correct?
It will be fine for that small of an amount of time.
Discussion Starter · #23 ·
Other than cleaning out the bore as suggested earlier, is there anything i need to do to properly install the bushings and boots? How much silicone grease should I use?
Thanks again. Everyone has been very helpful and I appreciate it!
09 V6 Highlander AWD , 15 Corolla LE
Just clean and use a small amount of grease...if you use to much, the pins will want to come out on their own…..
(Cleaning the slide pin holes)
(Hardware preparation)
(Caliper slide pin lubrication)
Discussion Starter · #26 ·
I would think 'emery paper' would be too abrasive. (I would think using a fine grit metal sandpaper would be used instead of what was in the video) Shouldn't the bore be smooth?
You can probably use brass gun cleaning brushes. I am sure a 9 or 40 SW brush would be sufficient.
Especially in the rust belt, you should be cleaning and lubricating your brakes every 30k/36 months. I would also suggest you coat your hubs with Anti-Sieze and Fluid Film or something similar. No, this isn't in the manual, but it is a good rule of thumb.
I would at a minimum remove the slide pins and clean and lubricate them. You might want to do this every spring.
+1 on coating the hubs with Fluid Film. In two of my vehicles (not Toyotas) rusting/ corrosion can 'weld' the wheel to the hub making it damn near impossible to remove the wheel. You would not believe how I struggled to get wheels off - you would swear they were welded in place....A cheap/dirty approach is to coat the hub & inside of the wheel where it bolts up to the hug with NeverSieze...
イリジウム
Yes, as well as some paper towel on a screwdriver carefully. Because of the grease (or what little of it left) and the boot, the bore should be fairly clean?
A light coat of grease is sufficient. You don't have to plaster the thing. The boot might wipe some of it off inserting the pin, so you can use a screwdriver to coat the bore a little.
Discussion Starter · #36 ·
One more noob question (actually 2). The old pads had a shim and an outer plate (that was in direct contact with the caliper piston). A)Even though the new pads came with shims, do I use that outer plate? B)Should I put a thin layer of Silicone grease on that plate(if i am supposed to re-use it) or on the shim (or both?)
Thanks again!
Administrator
マズダスピード3
That plate is for OEM pads. Keep those plates.
Yes, reuse the stainless Toyota shims. I place brake grease on the back of the pad (between the shim and pad) and then on the caliper ears and plunger/cylinder.
Discussion Starter · #39 ·
The pads I used have the shim permanently attached to them. Cannot put grease there. You put grease on the caliper plunger lip, correct?
Yes, I put grease on the caliper piston lip. Some people don't do this, but it is a point of contact.
21 - 40 of 63 Posts
