1 - 13 of 13 Posts
30YRTOYOTAPARTSEXPERINCE
04 Camry; 09 Sienna
If you have the 5SFE, the cat bolts right onto the exahuast manifold.
04 Camry; 09 Sienna
$447.93 MSRP, TN MEMBER $348.32. Not a whole lot of mark up on this item either.
25508-74090
25508-74100 for CA SPEC car
25576-74030 gasket.
04 Camry; 09 Sienna
With the Cat missing, I highly doubt it. But I do wish you luck and if you can figure it out, there are a whole lot of people in here that will be knocking on your door.
'91 MR2 Turbo
You won't pass emissions without a cat. Go to EBay and buy a small high flow cat.
and have it welded in. You may have to change some piping.
Or if you have the stock exhaust sytem, put it back on. But as old as the cat may be, it may not pass either.
Midship Captain
1991 MR2 Turbo
I can see the English language is really failing in this thread.....
I had the same problem when I built my MK1.5 MR2 a few years ago when MA had emissions. I bought a Magnaflow 3-Way/Hi-Flow cat from summit racing. They go for about $50-$60. You could probably have it welded in for another $50.
1MZ powered MR2
1991 MR2
nah i bought this car in MA like this n CT are a pain in the ass with the emissions damn ill c if i could try to find the stock one for cheap
The stock one won't bolt up to the header you have, so I'm not sure why you're going that route.
Buy a Magnaflow OBDII cat (or another brand if you can find one cheaper).
Magnaflow rear OBDII cat for $97 NEW
Part # listing for converters at Magnaflow
The front cat they list isn't the main cat like it should be (listed as a pre-cat), so just buy the rear one. You'll pass with flying colors if nothing else is wrong with your engine.
1 - 13 of 13 Posts
