1 - 5 of 5 Posts
G
Anybody hear anything about Toyota and Diesel hybrid. I heard it was
going to be a truck, a one ton or more.
You know, everybody makes mistakes when they are president.
William J. Clinton
G
Discussion Starter · #2 ·
In article <[email protected]>
[email protected] "The beneVolent dbu" writes:
It's quite possible. Remember, General Electric are developing a
hybrid railway engine (big, US style, long distance hauler).
Andrew Stephenson
G
Discussion Starter · #3 ·
"Andrew Stephenson" <[email protected]> wrote in message
news:[email protected]
> Andrew Stephenson
General Motors' Electro-Motive division has been making diesel-electric
train locomotives for a very long time, and diesel-electric submarines were
the norm before the advent of nuclear powered subs. The diesel engine turns
a generator which supplies power for the electric motors that move the train
or power the sub.
Ray O
G
Discussion Starter · #4 ·
[email protected] "Ray O" writes:
> diesel-electric train locomotives for a very long time, and
> diesel-electric submarines were the norm before the advent of
> nuclear powered subs. The diesel engine turns a generator
> train or power the sub.
Thank you for that insight, which of course had eluded me for lo
these many years. ;-) That's why I wrote that GE are developing
a "hybrid", as in the current use of that term in Toyota cars.
GE may, of course, simply be modifying a standard diesel-electric
set by adding generators and big traction batteries, with Prius-
style fancy electronics to manage the electric power. We'll see.
A recent GE shareholder report suggested regenerative braking can
save around 17% (seventeen percent) of the energy required to run
such a beast. The battery bank hardly bears thinking about; but
a sketch with the item showed many separate batteries (each quite
bulky) packed into sundry corners of the vehicle.
In the case of a hybrid car (eg, Prius), quick engine starting is
important. I imagine a railway engine need not start its engine
so promptly (maybe they'd have a couple of minutes' notice -- at
least), hence a diesel would suit that application fine, assuming
they ever shut off the diesel and run electric-only, rather than
using the electric drive merely to augment the diesel.
Andrew Stephenson
G
Discussion Starter · #5 ·
Sorry, I thought you were pretty knowledgeable about things with IC engines,
but you never know, hence my little history lesson.
> Andrew Stephenson
I suspect that GE is taking the diesel-electric setup to the next step like
regenerative braking, more sophisiticated controls and traction mkotors, and
perhaps batteries and then calling the setup a "hybrid" to take advantage of
increased awareness of the term.,
Ray O
1 - 5 of 5 Posts
