1. Did you have to get different wheel lug bolts?
2. What shape lug bolts are on a Camry/solara? See
diagram
3. Would NAPA or a similar auto part store have hub centric rings and wheel lug bolts?
4. Can we see pics of the Tiburon wheels on your camry. Did they bolt right up once you got your rings? Any problems?
5. How are wheel lug bolts installed?
1. No. Toyotas don't use lug bolts, they use lug nuts. My Camry (with stock steelies) came with conical seat lug nuts, and that is what the Tiburon wheels used too. Different wheels may require different seats, but they will still be nuts, not bolts.
2. conical / tapered for stock steelies, flat for stock alloys. Both have a thread pitch of 12X1.5mm
3. NAPA, Advance, PepBoys, etc. should have the lug nuts. I don't think any of them have hub centric rings. I got my centric rings from a local speed shop called American Speed Center.
4. These wheels fortunately bolted right up with no problems or modifications. Hub centric rings shouldn't affect how wheels bolt up either. Here is the pic as requested:
5. Once again Toyotas don't use lug bolts, they use lug nuts. Installation is simple: step 1 take off old lug nut, step 2 put new lug nut on.
