1 - 9 of 9 Posts
Hello, recently bought a Corolla 2001 3 speed automatic with 96k miles,what type of fluid should I use for the differential ,planning to drain and fill it.The manual says automatic dexron 2,the same for transmission.
Toyota eventually went with a one-fill-one-drain solution on newer transervese engine swith an automatic transmission. So the differential uses ATF from the transmission. If you are unable to find an additional drain and fill hole for the differential then you should not need to do it.
Manual transmissions do need differential fluid.
Any new Dexron fluid will work it is the only fluid in the transmission there is a drain on the pan and fill it though the dipstick tube
1997 Corolla
The 3-speed A131L has a separate differential. Filled and drained through separate holes. Many a differential has been lost by people not realizing this!
Discussion Starter #6
That's right,I need to add a small amount or maybe replace all the fluid.
1997 Corolla
Make sure you can open the fill hole before you drain the fluid. The fill hole plug is hard to get to.
1997 Corolla
Could you post a link to that DIY? I don't see it. I only see a DIY about changing the transmission fluid on the A131L.
1 - 9 of 9 Posts
