Saw that a lot working in a radiator shop. The dirt, debri ,rust etc. settles into the low spots and gets caked in with the regular temp changes. We used to pull the thermostats out and open all the heater control valves and flush them until they ran clean. The heaters in all cars are notorious for holding muck in them. Problem is if you get to aggressive, i.e high water pressure or adding air during a flush Murphy's Law says if you end up with a leak it will be in the heater core.
If it really bothers you, you could get super pre-emptive and put a new Denso radiator, radiator, heater hoses, new stat and cap. Barely over $100 bucks worth of parts. Only leaves the heater core and block that might have some residual gunk in them.
Sounds like it runs good and the compression numbers are excellent.
