G
Guest
·My 90 Camry is leaking oil at the distributor. I took out the distributor.
But I didn't see any obvious o-ring or gasket (on the Valve Cover side) that
can be replaced. The only thing I saw is a black soft thing (looks like an
o-ring) embedded in the middle of the shaft ( valve cover side). I don't see
how it can be replaced because the shaft looks like a whole piece and can
not be separated.
Is that black ring the distributor O-Ring? How can I replace it? Cut it off?
a trick to separate the shaft in half to take it out?
Or my only option is to replace the distributor? Really don't want to spend
hundreds of dollars on this car.
Thanks for your help!
ZR
not be separated.
ZR
