1 - 1 of 1 Posts
Good afternoon to you all. I'm new on this board. Nice to meet you all.
I am working on a 1992 Camry LE with the 5SFE engine. I'm not getting any spark from the wires. The coil was checked for proper resistance across the primary and secondary. I pulled the distributor out and found that most of the insulators on the wires were dry rotted and cracked or torn. The condensor wire insulator is also dry rotted. Is simple insulator cracking enough to cause a total distrubutor failure? If so, is there a company that sells a full rebuild kit with the pickups and all? Thank you for your time...
Earl
[email protected]
1 - 1 of 1 Posts
