I bought a 96 camry for the engine not knowing it had a distributor instead of coil pack, ive heard you can pull the distributor and just plug the end of the cam, which size plug do i use. Also are there brackets already prefabricated to mount the coil packs. Or should i remove the bracket from the 97 and have it duplicated as im wanting to completely rebuild the 97 so i have a back up motor. Or is the bracket for the camshaft position sensor that im thinking will need a bracket?
