1997 Camry LE 2.2 178K miles, Texas
I want to DIY
Oil Change
Transmission &
Differential Fluid
Replace Air Intake Hose
Clean MAF Sensor
For oil change
1-what capacity does this car take?
2-I don't want to put the wrong oil, so I saw these 2 oils at Wally world and I am wondering if the synthetic blend is better over the Mobile high mileage?
3-For this mileage is there an oil additive (my friend mentioned Lucas high mileage) that is recommended?
Transmission & Differential
This car has never been done either of this at least since I acquired it 10 years ago at 90k miles. I have heard that changing transmission fluids could cause issues because the gears have become used to, and set themselves, to the metal shavings in there, etc. I don't know what to make of that as I am just getting into DIY maintenance. Is this hogwash?
1-What fluids are recommended, capacity and viscosity?
2-What is the frequency recommended for changing?
Air Intake & MAF Sensor Cleaning
I will replace the Air Intake Hose as it's cracked and the new one is here. While at it I might as well clean the Sensor. Which cleaner is recommended? I saw these at Wally
Belt Dressing
My buddy swears by dressing belts and sprays Preston belt dressing product. Is this recommended or does this negatively impact belts? If so about what frequency?
I want to DIY
Oil Change
Transmission &
Differential Fluid
Clean MAF Sensor
For oil change
Belt Dressing
